vcProcessExecutor
Process executor is a behavior that holds and runs process routines.
Parent: vcBehavior
Referenced by: vcTransportNode.ProcessExecutor
CurrentStatementvcStatementRGets the statement currently being executed by the process executor.
ProcessesvcList[vcRoutine]RGets all process routines in this executor.
RuntimeError: When the executor does not have a program. This can occur if called too early during layout/component loading.
TransportNodevcTransportNodeRWGets or sets the associated transport node that this executor's processes use to receive and send product instances.
node (vcTransportNode): Sets the associated transport node.
createProcessvcProcessRoutineString nameCreates a new process routine and adds it to this process executor's processes.
name (String): The process name has to be unique within this process executor's processes.
vcProcessRoutine: The newly created process routine.
RuntimeError: When the executor doesn't have a program. This can occur if called too early during layout/component loading.
ValueError: When given process name is empty or not unique.
Example: Access Process Statements
"""Read the process statements of a routine in Process Editor found via process executor behavior."""
import vcCore as vc
comp = vc.getComponent()
exec = comp.findBehavior("ProcessExecutor") # vcProcessExecutor
routine = exec.Processes[0] # vcRoutine that inherits from vcScope
print (routine.Statements) # access the statements of the routine
Example: Create New Process Statement
""" Creates a new process statement and sets the property values."""
import vcCore as vc
import vcExecutor as vc_ex
new_statement = routine.createStatement(vc_ex.vcStatementType.PROCESS_SET_PROPERTY) # createStatement from vcScope
new_statement.TargetProperty = "x"
new_statement.ValueExpression.Value = "y" # set the value of vcExpressionProperty
Example: Delete Process Statement
""" Deletes a process statement."""
import vcCore as vc
statement = routine.Statements[0] # take the first statement of the routine
statement.delete()
